Crunk Times, My friend.....Crunk Times
Thats a cheap feature, so you have to ask yourself how many you really need. I can see since this will be your only PC then perhaps you may need a lot(I don't know). I don't because I use my laptops to walk from room to room and access things attached to all my desktops.
If you nee dmore a hub can be purchased in the future.
Pfft. On can only ***** as fast as the forum will move. That forum moves 3x the speed this one dies. Won't be a problem at all.
Bull shit it did. You know you only had 2k posts when Spider Monkey arrived.
Fact is, it still took 4 years from my join date to achieve. Silly monkey. Mathematics escapes you.
I see...
I thought since I would have a real keyboard and mouse hooked up to it when I was using it at the house, I would need more.
Plus, I figure I would get a mp3 player and then I could hook my camera up...so really, 3 is enough.
Oh, you can't use the keybpard on it even if the touch pad is defeatable? I'd get a defeatable touchpad. I can type on the laptop keybaord, but I do need a real mouse. You may need more than. If this is for work and school, you may find the need for a printer/MFC, so there is another needed port.
The current mathematical structure is wrong and has been proven so, therefore I do not believe in it.
I only believe in things of truth and fact.
Mathematics holds true until we break it way down. As far as adding and subtraction it is truth/fact, fool. Acceleration in the rate of achieving this feat may have changed with certain events, but that doesn't make it any less true that it took 4 years.
With my laptop i got a hub and plugged in my mouse, keyboard, flash card reader (i dont like the ones built in), external hdd's, etc.
Not nessicarly for the extra ports, although those were nice -- but more for the easy of only having to unplug one cable when i decided to go get coffee or something.
I use the keypad thing to the right quite a bit. The one with just numbers. I haven't found a laptop with them there. I'd be lost using the numbers at the top of the letters.
Yes, I understand. I have a USB number pad for when I need it. For most things I don't so it stays stored.
I was thinking something like this too. It may be more efficient to use a hub if the peripherals being connected are meant to stay at home on the desk.
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
ThxOne
    May 25, 2026
