crunch ground pounder 3000 pro vs ap3000d vs AQX-3500.1
all do rated. some say the crunch does a little more then rated. and i think someone on here said the aqx did 3700 or more at .5ohm
can only go down to 1 ohm and up to 14V so 16-18v and 1/2 ohm and less wont matter to me... but glad to hear GP and AQX do well.. they close in cost as well?
Thanks!
crunch or aq3500. both are very strong and you will be equally pleased. its up to you though man! there both strong amps
they priced similarly as well? Got a dealer givin me info on the GP, dunno bout the AQ though
thanks!
Another dumb thread indeed, they all do rated so only you can pick which one you want:rolleyes:
yup youre right. guess i don't know or understand what the forums are for
Annarbor gives out false info on shit he knows nothing about, dont mind him
Id go with the Crunch out of the 3 though, AP is a sketchy company
Haha ap is a great company. I have been using their products since 2006 and only had 1 problem and they took care of it!
For what its worth as was said earlier you may have a tougher time finding the crunch new so depending on what ohm load you need the power in i would choose between the a-pipe and the AQ
Thanks!
thanks!
Correct you apparently do not, or you would have known by using the search button, that they all do rated power, but the AP is a few hundred dollars cheaper. Thus it becomes a personal choice as to which one you get;)
the aqx is about 420 new on egay. the crunch is about 400 used on here and the ap3k is about 275 used on here or 320 new on egay. but if we are throwing the AQ 3500d in here as well, they are about $450 used on here and 550 new from AQ's website.
this^^^^
just because there isnt a thread with the exact same info, doesnt mean you cant search for each amp individual and find the exact same info we have given you.
haha right on... ya sounds like I can get a good deal on a pair of GPPROs
maybe my deal wasnt so good after all. good thing I did start this stupid thread, I was looking to spend $600 a piece on ground pounder 3k pros //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Kryptonitewhite
Kryptonitewhite
soo foo sd
Kryptonitewhite
