Crunch Amp Strapping
tapout383
Just boughta Zone.
The 2500D is an entry level model and will do 1250w RMS.
a strapped pair will be hard pressed to produce 2500w and will be 2 ohm stable strapped.
The 3000D Pro is a high end model and can do almost 4000w if you have the voltage.
A strapped pair can be run at 1 ohm and you will get over 8000w with a strapped pair.
The 2500D is an entry level model and will do 1250w RMS.a strapped pair will be hard pressed to produce 2500w and will be 2 ohm stable strapped.
Thats what I thought, but wasnt for sure.
I Have Tested The Gp3000 And Ill Tell You It Did The Same Numbers As My American Bass 200.1 As Follows
.25/18v 4 Powermaster Batts=5600 Watts Clamped
That Was Good Enough Off 1 Amp To Win Me A World Championship Last Year In 0-600 Prostock At 159.6 Db's.
We Did Have A 160.2 Before Finals But A Crx Only Holds Up In The Back Wall For So Long Before You Start To Destroy Them Oh Well All In All These Are Both Great Amps.
tapout383
Just boughta Zone.
tapout383
Virginia
sanman
