cross overs
  • 2
does any one know much about those confusing things, I have two 400 watt alplin mrvt407 amp set at 2ohms, running my for front speaker which consist of (2 3 1/4 an 2 4x6's per side) first amp , then the rear is pushing 2 6x9's and 2 component sets. and I have a visonik 1500watt mono block, running AT 2ohms pushing two hollywood 12 inch excrucion. this xover is a custic , with front in, out, rear in, out, and center, and sub . what should I do, loose the xover ore try to set the xover, this does not seem to be matching the right tone ins .
you have way to many source points to really make heads or tales of anything as well as different speakers with different power handleing. and it looks as if you have the party going on in the back seat:eek: look up and read on theories of superposition then re evaluate your system i think you would and definately could do more with less. one rule of thumb i can help you with is a smaller coned speaker with a small motor structure cant handle hi power on low frequencies as well as larger speakers. i am not saying what you have cant be simply helped from this xover it is just too confussing to offer advice on line without seeing and listening
Check out Focal. I believe they have direct replacements for many Toyota's...
4
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
It depends on the brands they want to use. I would go with speakers first. If they sound great on radio only, then I would add the amp and sub...
A-hole
Banned
A-hole
Phoenix, az (hell)
audiolife
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
