Critical Mass UL12
Subwoofer Size: 12”
RMS Power handling: 2500 Watts (undistorted power)
Peak Power handling: 5000 Watts
Recommended Box Volume: 1.2 cuft. (Sealed)
Weight: 16.6 lbs
Motor Type: Dual Gap / Internal NEO Magnet
Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA)
Voice Coil Diameter: 3”
Voice Coil Impedance: 1.5 ohm nominal per coil
Xmax (one-way linear excursion): 36 mm (3” peak-to-peak)
Maximum Excursion (one way): 46 mm (Almost 4” peak-to-peak)
Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
Fs (Klipple-LSI): 31 Hz
Qts (Klipple-LSI): 0.81
Vas (Klipple-LSI): 47.7 Liters
Thats all the technical info
One of these should work :
They're 5kw, here is the manual : http://video.snoopdan.com/adassa_warlord.pdf
Im running two, I have no problem powering anything.
//content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif thats some massive power but it is also a massive sub do you have a picture of your setup that i could see
what i hope your joking right, he has 2 warlords and a stock alt, lmao.
You do notice that he posted the guy has a "bunch" of batteries back there, right //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Morgan
GTMustang04
I leave vettes in my dust
GTMustang04
Little Rock, Arkansas
snoopdan
