Crescendo 3KWP vs DD M3
Ok class in session..... Next time your playing it full tilt, hook up a dmm to the power and negative terminals and tell me what your voltage is on your puny 1200s... IT ALL DEPENDS ON THE BATTERY BANK AND RUNNING High Voltage=HV...... INORDER TO REACH 14V WHILE ON THE "STREET"
I have a steady 14.2 voltage with subs full tilt you twat faced moron.
pretty easy on only 2000 watts after impedience rise and multiple batterys... your not even worth my time
You are beyond fucking stupid, you know that?
And //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif , i don't run 1200's any more, I run the crescendo 3000 . Go back to playing with your pyle sh1t.
I hit a 150db in my charger with 1 DD9515G and was invited to world finals and as i left the lane i played jeezy on my way out and gave demos... i now have 2 DDm3a's so i guess thats like 2.5 crescendos? Get your stacks up and play the game... might wanna buy a book too
DD will be overpriced FOR POWER?!?!?!?!?!
AGAIN WHATS WITH THE NOOBS TAKING OVER THE FORUM! IN ORDER TO EQUAL THE SAME POTENTIAL AS THE M3A GIVES YOU WOULD NEED TO RUN A HV SYSTEM WHICH IS A PAIN FOR ONLY 4000 WATTS!!!!! The m3a would simply need a batcap 2000....
Please delete your accounts guys, your really giving bad advice.
And to mr smarty up there who says im only 19, i made this account 3 years ago...
still overpriced for the power
DD M3's are strong amps....I did a 151.3 with a single 12 on a single DD M3 at a show in Fordyce Arkansas this summer that was on my daily beater box tuned at 38hz in the trunk of my Mustang...I've ran M3's in numerous other setups and they have no problem running daily at .25 loads....They are also really efficient and don't draw near the current of most class D amps and were designed to get near class AB sound with class D efficiency...Id def run the DD M3 over some noob brand....that most likely has underbuilt power supplies instead of overbuilt like the DD's
crescendo is not for noobs, bro.
The 1st GEN. M3 was pretty much the same Zenon board as the Crescendo 3k, as well as alot of other amps , both are good solid amps so who gives a ***** what name is on them.
rezzarect
rezzarect
CA
Louisiana_CRX
