Crescendo 3500 or 2 AQ 2200d
should sound great right up to the point the amps go up in smoke taking the subs with them.
"Right to the seen of the crash!" hahaha just reminded me of that...
like i said before bro... with what your going to be running, and wanting to run a single amp... the 3500 is going to be your best bet... i'll bet a months salary that it will pull less amps than the 2 2200's, which is where you will run into the most problems... due to your batt situation. and since your building a daily, and not a comp vehicle, i dont really see you doing too many burps, and "pulling 700 amps" lol... just dont see that happening
and like i told you before... monitor your voltage, and if you see alot of drop, than add a smaller batt in the location you have, just to help out
okay, his subs are DUAL 2, so what? hes going to run the 3500 at 2 ohm and maybe get 900 watts to each sub? no. you either need an amp to do 4000 @ 2 ohm or get two 2000 watt amps that d0 2000 @ 1 ohm to get the power you want.... and on music your amps would be pulling about a 3rd of what they fuse at on average
I still dont understand how one amp pulling the same power as two is gunna pull less amperage?
---------- Post added at 01:57 PM ---------- Previous post was at 01:57 PM ----------
And besides it doesnt matter he already order a 3500
one amp at the same power will almost always be more efficient than 2 .... just sayin... not saying that every amp is that way... but in this case, since the bc3500 is fused at 300, and the 2200's are fused at 200 each, i have a VERY strong suspicion that the 2 2200's would pull more amps than the single 3500.
i highly doubt seeing that crescendo go "up in smoke" at .5 as well (their previous models were warrantied at.5)... unless he completely ***** up the electrical... but thats why i told him to be cautious at first, and always monitor his voltage
all depeneds on his electrical. Also there new stuff is made in a completely different place. They changed where the amps are manufactured.
Bassin Brandon
Bay Area, CA
twistedchild420
