Couple of Questions for Box Build
I am building a box so that I can fit two Sundown SA12's or two Alpine Type R 12's under the seat of my 2000 Silverado ext. cab. I will post an attachment of the dimensions I am working with. The only difference in my box will be that the subs will be down-firing. I can add up to 2.5" seat spacers if necessary to accommodate air space.
Here are the specifications for the subs:
Alpine Type R 12
Minimum ported - 1.0 cu ft.
Maximum ported - 2.0 cu ft.
Mounting depth - 6 3/8"
Sundown SA12
Minimum ported - 1.5 cu ft.
Mounting depth - 6 1/2"
Questions..
How far should my cone be off of the floor?
What should the dimensions be of my port?
What thickness of MDF should I use?
Should my mounting surface have any thicker MDF than the rest of the box?
bradch
bradch
Michigan
bradch
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
