couldnt find through search.. 4ch bridged vs 2 ch
ninobrn99
Is power cleaner from a straight 2 channel amp vice a bridged 4 channel? Ive been looking at quite a few amps and would like to get ~200w rms for my comps.
Ive been looking at the following amps:
Clarion DPX2251
RF P400a4
RF 850.4
Cadence TXA 3004 ( I used to have a ZRS9004 that my dumbass sold //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif)
THD for these I think are all .05%, but how do you determine what it is bridged? Do you multiply it by 2 or is there something else?
Err, generally bridged is power x2 at 4 ohms.
let me show u an example...
this is for the TXA-3004
4 Ohm RMS Power: 4 x 75 Watts @ 13.8 Volts
2 Ohm RMS Power: 4 x 150 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 2 x 300 Watts @ 13.8 Volts
See how it is 4 x 150w at 2 ohms?
Bridged it would give u 300w...
Umm, no. That would be either a 2 ohm SVC sub or 2 SVC 4 ohm subs ran in parallel on a single channel. I think you're confusing paralleling with bridging.
irrelevant either way //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif THD Cleaner or not
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
one more question. Would the Cadence txa6004 be too much for a set of components? I couldnt find if it was a class A/B or D amp.
Headroom is good. You dont have to have all of the power going to the comps. Jus set the gaines properly with a DMM an youll be good.
depends on what components. Seems to me ~125w/chan should be plenty for about any good components to sound their best. If you have components you think would benefit from ~200w vs ~125w (the txa's are a little over-rated) then I don't think the THD is really an issue.
Completely inaudible at 4 ohms stereo vs still inaudible at 4 ohms bridged is inaudible either way.
I went from a 90x2 amp to a bridged 50x4 (180x2) and the results were great.
ninobrn99
ninobrn99
honolulu, hi
ninobrn99
