Could My Kodas Use More Power..?
n0ftInc
Spoilers Up. Kula Style.
So I picked up the 6.1 setup awhile ago and I know they are rated at 1oowts. I scored a good deal on an Orion 2002 (50wts) and have had them hooked up to that. Now, I have my gains set at about 45%. I notice though, when I turn up the volume quite a bit, the mids will start to bottom out. I would like it to be louder, if possible. If I were to purchase a higher power amp, would I notice a difference, or will I still have this problem?
Just out of curiousity, why am I bottoming out with such low gain on such a small amp?
I have moved my post*****ness to michiganvw.org. I am on here a lot, but I usually don't post unless I am baffled..like I am here.
how well do you have them installed? no gaps around the mids?
I do have some gapage at the bottom. I never really even thought of that. Scientifically, how does this affect my mids? Canelation causing the noise?
My HU doesn't have an internal amp..sorry.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Umm..so..to clear up confusion..
The Mids arn't flush-mounted. What affect does this have..?
Will I have my gains turn down severly with a larger amp..?
Bad Example: Since my gain is at 45% with the 50wts, would a 100wt amp mean gain at 20%..? Thus making it worth the $$$ to buy.
the woofers need a more constant pressure to the air around to driver front and back. if air the same air moves from front to back you have what i call a negitive air suspension meaning it will handle far less power. even in a "free air application you must seperate the air between the front and back of the speaker.
n0ftInc
n0ftInc
A Foolish Pleasure In MI..
audiolife
