Could I go ported?
Robster13
Howdy,
I was planning on building this box sealed, but I wonder if I could make a ported box near these dimensions.
http://chicagocomp.net/robs/12inchboxwrangler.bmp
I can go a couple inches wider and taller, but not deeper.
I am starting w/a Pioneer 306c 12", but plan on upgrading to a stronger sub in the future. (Maybe an x-mas present?) //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
The reson I'm asking is because of the shape of the available room I have. (Going into a jeep wrangler)
Would I be able to make it port out of the top?
Thanks for any & all help!
//content.invisioncic.com/y282845/emoticons/thankyou.gif.5451126d09e870f796f50c3a4dd5acd7.gif
Come on, I know one of you gurus here can help me out....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what are your max deminsions u can go and ill try to help
Thanks!
As I said, the depth has to stay the same to clear the hinges on the jeep, but I can go to 31" across, and up to 22-23" in height.
The depth is 11-12" at the bottom, and 8" at the top.
Thanks again! //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
I have built a box for my last jeep wrangler. These dimensions assume you use 3/4 MDF.
Top depth: 7"
Bottom depth: 10"
Height: 16"
Width: 29"
Throw a 3" diameter port @ 6" long in it wherever you like and you're good to go.
Top depth: 7"
Bottom depth: 10"
Height: 16"
Width: 29"
Is that interior measurements?
What ft3 would that give me?
Thanks!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Exterior dimensions. Sorry, it should be 30" wide.
((10+7) / 2) - 1.5) * (16-1.5) * (30-1.5) = 1.675 ft^3. Subtract port volume (.02 cubes) = 1.655 cubic.
Exactly what you're sub requires for a ported enclosure.
So it's 7" top, 10" bottom, 15" tall, 30" wide.
My plan was to make the enclosure a bit too big so I could move up to a different sub in the future.
Would this be wise?
Because of the detail in the box (lighting, plexi-panel, vinyl) I didn't want to have to make a new box if I move up to a better sub, likely DVC.
And just to be sure, this is with a round port 3" wide x 6" deep?
Thanks again!
All external dimensions.
height: 20
top depth: 7
bottom depth: 10
width: 30
volume = 2.13cubes - port displacement = 2.11cubes Subtract woofer displacement, and pretty much right below 2.1 cubes.
Yes you can swap port tubes later. And yes your current port needs to be 3" diameter x 6" long
height: 20
top depth: 7
bottom depth: 10
width: 30
Excellent!
Thanks for your help, and I plan on taking a bunch of pics when I do the build.
Just to reitterate, I can put the port pointing pretty much any way?
Excellent!Thanks for your help, and I plan on taking a bunch of pics when I do the build.
Yup, you just don't want to put it on the ends becuase it won't have anywhere to breath to.
Robster13
Robster13
Chicago
ultimate157
