cost effective way to help my electrical system
JMPisGOD
I have a feeling my electrical system will suffer with this new setup.... i have a 94 civic (DX model electrical system, which i think is probably bad) and im bridging a class AB amp down to 4 ohm mono... The amp is a Rockford 700s 700watts x 1 bridged @ 4 ohm and requires a 60A fuse... Whats the most cost effective way to help this? i heard getting your alternator rewound is expensive... What should i try first?
jmpisgod-try wiring your amp and sub
up frist after you get your system up
and running start you car then turn
on your cars headlights
if they dim real bad when the bass hits
then you will need to upgrade to a higher output alternator.
if there is no dimming of the headlight
you;ll be ok with you cars stock alternator
charging system
with my previous system it was less watts and i expereinced no dimming, but sometimes all my sound would cut out for a second...my feeling is that upgrading to this amp would only make it worse... i just need to pinpoint the problem so i can fix it... if anyone knows what is wrong please help
To suckmike...
Have'nt hooked it up yet, waiting for the solobaric to come, ill let you know
peace
Depends on how much power you need and whether you plan on upgrading in the future. It wouldn't hurt to call a shop and get an estimate. Also check online or call your local dealer and find out rates on new altenators. If you have a wrench you should be able to install the new altenator yourself.
JMPisGOD
JMPisGOD
Sacramento
Phatillusion
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
