Considering upgrading my Amps.
Radioflyer97
C.E.O.
I'm currently running a pair of Alpine MRP F250 amps to a set of 4 Alpine SPX 177r comp speakers. The amps are bridged at 100 Watts x 2 output. I'm looking at the slightly larger (and reasonably priced since last year) MRP F450. It's only 2 inches wider than my current amps and would fit in the same space in my Amp rack. It would also accept the same KOL 8 power/ground wires i'm using. (my current setup has the amps as the weakest link)
Ideally, the MRP F450 model would supply 200 Watts per channel. The SPX 177r speakers have a peak power handling of 300watts and I feel the Woofers are being significantly underpowered.
Thoughts?
If I'm reading right, their RMS is 75W, which is A LOT under 200W. You are definitely not underpowering them. Next time, don't worry about peak power, just RMS.
Radioflyer97
C.E.O.
Radioflyer97
earth (for the moment)
Radioflyer97
