Depends on how you wired them.
Wire each sub's coils in series, then parallel the subs together and you'd get 1.33ohm.
I think that's the most practical wiring, and the one I'd suggest.
You're other options are a final load of .33ohm (series/parallel the sub's coils, then parallel wire all the subs) or .75ohm (parallel wire all the sub's coils, then series the subs). And finally 3ohms if you wired each sub's coils in series/parallel and then wired the subs in series.
.75ohm might not work too bad either, after impedance rise you'd likely be over 1ohm most of the time, so it should work with any 1ohm stable amplifier. Or wire to 1.33ohm to be on the safe side.
