Conductive Bolts?
Looking to install bolts instead of terminals on my new build.
are there special bolts i should be looking at or will anything be fine?
You could try to find solid copper bolts at your nearest electric store. They are pretty pricey tho but any other regular bolt will conduct electricity. I hate Doing anything to terminals or bolts because any connection between the amp and subs will cause more resistance. I like to just drill the hole the diameter of the 8ga wire any pull that bish through straight to the coils.
Thanks, I'm going to run by radioshack and check it out.
Unfortunate
Unfortunate
Norcal, CA
Unfortunate
Mike Mccabe
