computer question...help
andar
Ok so I have a dell dimension 2400 with a celeron. I want to get a new motherboard with PCI-e. If I get a board with the same size socket and transfer all of my existing hardware over to the new mobo, but the new mobo has a higher FSB, will i get an increase in speed.
i dont see why u couldnt make this work....
Don't do that. It'd be pointless. That CPU would severely hold back any decent PCI-E GPU, so you'd be much better off just building a new computer. Plus the fact that the 2400 is MicroATX, so it has a small case = no good GPU would fit, most likely. And then you'd have to upgrade your PSU too, so trust me, just build a new PC.
go on pricewatch.com and get a new CPU, motherboard and memory combo for cheap. maybe sure it will fit your case. or just start over and buy a new case and a good mother board and CPU, and all the junk, and slap it all together, with windows vista when it comes out.
I used my dell cd on my bros laptop which is an HP, it worked, except it didnt have the same drivers that were needed so i need to use the actual restore CD's. But it did let me install it.
I think on the newer Dell's you get you don't actually get an XP install disk, at least my friend didn't get one with his laptop. On my old old old desktop from Dell I got a XP install disk though.
yeah...well i am just trying for a cheap solution until i go to college next fall...i just want to be able to play games...maybe ill just get a geforce 5500 for reg pci
You might as well keep what you have now, that 5500 isn't going to play anything newer than '98 //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
You could build a half decent PC for $700-$800 though.
andar
andar
Royal Oak, MI
luvinthebass
