computer guru's
Stuff you should try:
first, do this: start->run->type in: cmd
--1---
type in: ipconfig /all > c:\ipinfo.txt
--2--
type in: nslookup caraudio.com >> c:\ipinfo.txt
--3--
type in: ping 67.45.54.4 >> c:\ipinfo.txt
for ex:
Code:
C:\>ipconfig /all > c:\ipinfo.txt
C:\>nslookup caraudio.com >> c:\ipinfo.txt
Non-authoritative answer:
C:\>ping 67.45.54.4 >> c:\ipinfo.txt
C:\>
throw the contents of ipinfo.txt up here.
Here's my output for example (...come hack me...):
Code:
Windows IP Configuration
       Host Name . . . . . . . . . . . . : K7J6LSSBWET
       Primary Dns Suffix  . . . . . . . :
       Node Type . . . . . . . . . . . . : Unknown
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
       DNS Suffix Search List. . . . . . : hsd1.il.comcast.net.
Ethernet adapter Local Area Connection:
       Connection-specific DNS Suffix  . : hsd1.il.comcast.net.
       Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter
       Physical Address. . . . . . . . . : 00-13-D3-A5-71-A0
       Dhcp Enabled. . . . . . . . . . . : Yes
       Autoconfiguration Enabled . . . . : Yes
       IP Address. . . . . . . . . . . . : 71.194.43.143
       Subnet Mask . . . . . . . . . . . : 255.255.254.0
       Default Gateway . . . . . . . . . : 71.194.42.1
       DHCP Server . . . . . . . . . . . : 68.87.72.10
       DNS Servers . . . . . . . . . . . : 68.87.72.130
                                           68.87.77.130
       NetBIOS over Tcpip. . . . . . . . : Disabled
       Lease Obtained. . . . . . . . . . : Wednesday, October 25, 2006 1:08:57 AM
       Lease Expires . . . . . . . . . . : Wednesday, October 25, 2006 1:18:57 AM
Server:  chic-cns.area4.il.chicago.comcast.net
Address:  68.87.72.130
Address:  67.15.54.4
Pinging 67.15.54.4 with 32 bytes of data:
Reply from 67.15.54.4: bytes=32 time=36ms TTL=44
Reply from 67.15.54.4: bytes=32 time=37ms TTL=44
Reply from 67.15.54.4: bytes=32 time=38ms TTL=44
Ping statistics for 67.15.54.4:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 36ms, Maximum = 38ms, Average = 37ms
denalilvr
just laugh
denalilvr
illinois
sumone
BP1Fanatic
BP1Fanatic
