comps/amp to match my sub stage?
wschmidt22
i currently own a cda-9885, and i have a set of AQ SD2.5's w/ the AQ1200D amp en route.
I'm still deciding on my comps/amp combo for my front stage... what are some brands/models i should look into, and how much power would be appropriate?
i plan on just running 2 comps in the front, and disconnecting the stock 6x9's in the rear.
vehicle is a '91 crown vic
i suggest you take your time on this, you couldnt even determine for yourself that your stock speakers were 5 1/4 even tho your tape measure clearly did not even reach 6 inches, and yet you still didnt know what size your stock speaker location was.
You could use crutchfields guide to find what size speakers would fit, not saying buy from there, it's just helpful sometimes. You could go with boston pro's or the PG's, if you wanted to you could try ddc5.25's (Digital Designs) they're in your price range. I have a pair, they sound good to me, the tweeters can be a little harsh sometimes but over all quality I think is pretty good personally.
wschmidt22
wschmidt22
J-Ville, NC
Platinumxpimp
