Compatibility question
The_Councillor
So I told my friend I'd help hook up his amp, and subs in his car as I've done it once before so therefor I must be the expert on car audio.
He bought a used amp off of someone and then purchased 2 subs
The amp is a Boss 850 Chaos Monoblock
Max power @ 2 OHM: 850W x 1
RMS power @ 4 OHM: 200W x 1
RMS power @ 2 OHM: 400W x 1
The subs are 2 JBL CS1214 1000 12
250W RMS
4 Ohms, SVC
After doing a bit of research and reading, mostly on crutchfield, I told him I wasn't sure if his amp was going to be able to power his subs, am I correct in this?
If the subs total RMS is 500 watts so the amp would need to put out between 375 and 750 Watts correct?
Which I see the amp is barley capable of at 2 OHM..
Question 2:
RMS power @ 2 OHM: 400W x 1...what does the "x 1" mean exactly in those ratings exactly? is that saying that that is for 1 amp or 1 channel since it a single channel amp?
Question 3:
Lets pretend that his amp will work
His subs are 4 ohms SVC connecting to a single channel amp is this the wiring diagram we would use to make the amp put out the 400W RMS at 2 OHM?
http://images4.crutchfieldonline.com/ca/learningcenter/car/subwoofer_wiring/2SVC_4-ohm_mono.jpg
If you guys need any more information let me know, thanks.
The subs will work fine on that amp. The amp is junk and will probably do more like 40-80 actual watts but it should power the subs for now until he gets a proper amp.
With normal amps that do rated power... 400 @ 2 ohms means 400 watts when it sees a 2 ohm load with the wiring configuration, its a monoblock thats it.
Just wire the subs parallel to the amp like in the diagram
10 awg is adequate for that amp, but knowing an upgrade needs to happen sometime soon you should probably just run 8 awg, it's only a few $ more.
Jeff is exaggerating a bit with the 40-80w comment. That amp will likely do 150-200w at 2 ohms.
A mono amp has only one channel, but it can power multiple subs. It just needs to be connected to an impedance no less than 2 ohms. That can be a single sub, two subs, or as many as you want. The power is distributed among the load so a pair of 4 ohm subs wired parallel for 2 ohms getting ~150w from the amp means each sub sees 75w.
Sub wiring:
http://www.sonicelectronix.com/product/img/subwoofer_wiring/2_subs_SVC_4_ohm_mono.jpg
After impedance rise and voltage drops thats basically what he will see. You'd be surprised how much sound subs can make with only 50 watts clamped going to them.
No, i wouldn't.
Might as well throw crest factor in too since the goal here seems to be to go into the weeds for no apparent reason.
The 150-200w approximation is what it would be if it were from a reputable brand.
The_Councillor
The_Councillor
Texas
n2audio
