Notloud00
Quiet
at the headrest? car off on music is Amateur street. car on on tones is street. see what you do both ways
at the headrest? car off on music is Amateur street. car on on tones is street. see what you do both ways![]()
you need small fuses //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif or you will be in a big class. you could run in as1 because i have the same setup as you. or s1. travis will pwn you both just like he did me so run in s1 and try to get a trophyI need at least a 2.5 cube box for a 15. Im with you tonkpils, I have never competed so I have no idea what class I would be in. I have one 15 and ideally will have a 1000 watt amp.
the fuse by the battery? and ive got a yellowtop with the big 3with my batt i did it for 30 sec with no prob. Kinetik FTW! a full run is 30 sec but i think a 40 amp fuse would last you 3-5 sec at most. i run a 50 amp fuse and can play a whole song before blowing a fuse with the car off:naughty: if you dont have a good batt then uh i would run in street 1. you probably arent close to travis's as1 score anyway.
