Combining Fiberglass Pieces
  • 4
djXternal
Tampa, FL
How well will a fiberglass piece bond to an already hardened piece of fiberglass...
for example, my enclosure i need to make in pieces to be sure i make it correctly, so if i make one piece and add all the layers, then let it harden... can i add fiberglass directly onto the hardened piece? and will they bond together well?
actually, a wirebrush would do a better job. or REALLY COARSE sandpaper.
then jut do it like you normally would.
//content.invisioncic.com/y282845/emoticons/needpics.gif.edd6d28e76618c28c46f343991bcced5.gif
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
960
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
djXternal
djXternal
Tampa, FL
req
    May 12, 2024
Brendon Jenness
    May 11, 2024
