cold???
If what you told me is correct its not a ground problem unless you body ground from your battery is bad , Is everything in the car working right except the amp
yes all the lights but the turn signs but that is the switch but the hazards and the head lights and high beams and the inside lights work and the engine great
Just need to check your connections and see where your losing power or ground at , i think its power problem , Start at the battery and work your way back till the power drops to the 7.5 volts or whatever from 13 volts and that your prob , The amp wont turn on with 7 somehting volts
what bout just puttin a new power wire right from the battery the fuse to the amp new fuse holder and fuse i have 8 g now and i wanna upgrade to 4 ga any ways
tbirdsony
tbirdsony
toronto
Spddracer
michigan born
    May 14, 2026
michigan born
    May 14, 2026
