Coffee table sub enclosure
dbornotdb
Custom Fabricator
I used the SEARCH, I promise.
I think it was Decware that I saw the plans for a "W" shaped enclosure that had a peice of glass over it and was used as a coffee table. I used to have that info saved, but lost it in a crash. Now I want to build it and can't find that info.
I looked on decware.com and came up empty.
Did I overlook it?
Do you know where to find this info or something similiar?
I am wanting to use a Power Acoustik FUBR 15 dual 2ohm sub since I have one for sale and noone is biting. So I might as well get some use from it right??
well only if he's gonna use a 12v amp...most 110v amps play better with a sound reinforcement speaker...a technician once told me something about sound reinforcement speakers not being for 12v and car speakers not being for 110v...i gave him the benefit of the doubt as he's been dealing with electronics for a while
I'm sorry, he's dead wrong. The speaker doesn't care what source voltage the amp is getting, only the voltage that the amp is supplying it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
"Car" subwoofers can do quite well in home, provided a little thought is put into the enclosure. Because the transfer function isn't the same at home as it is in-cabin, you have to design accordingly...
4 18's in rear loaded horns.....no ... TL'S!!!!
Look on the Decware site for the Imperial Horns...those are frightening.
car speakers can work in home and vice versa, its all enclosure dependant tho hell I'm VERY tempted to use some sx or xxx 18's in a sub cab for my drum fill/PA use cause the only GOOD 1000w rms 18's I can find only have a xmax of 10mm (some only 6mm) which when I plot eveything in bb6p the sub would be mechaniclay limited in a ported box slightly above tuning (30hz) with 1000watts going to them, but generaly if you know what your doing you can make it work very well, but most people dont and thats why it doesn't work for them, take for instance my 2 re8's sealed in a car the sound good, but in home they don't do crap, now take those two 8's and stick them in some TL's and you have yourself some loud 8's and not only can they get loud they also sound so accurate
but one quick question...can a car sub take as much pressure as a sound reinforcement speaker...i mean i've seen some of these speakers play for 3 days straight at a wedding
as long as its not getting a clipped signal or thermaly overheating I don't see why a car sub couldn't take three days of straight playing at clean rms, unless the rated rms of the sub is false
What do you mean, pressure? Are they as reliable for continuous use? If they're being operated within their limits (proper enclosure size for the power, unclipped signal from the amp), you'll have no problems.
dbornotdb
Custom Fabricator
dbornotdb
Bradenton, FL
myvanpounds
