Co2 sensor
Just O.......O2 sensor.
Are you getting a check engine light?
Depending on what year Civic you have there should be a idle screw on the throttle body,give it a lil turn and see which way is up than set it up a lil higher than you have it now.
Were you getting bad gas mileage before?
Just O.......O2 sensor.Are you getting a check engine light?
Im not good with motors so, The throttle is like pressing the gas under the hood rite??? Where the idle screw from that???
n/m, i don't want to keep checking back.
if your car is 90's or newer, you don't have an idle set screw
you have an idle stabilizer valve, which uses vacuum control to set the idle, sort of a primitive (less powerful) cruise control
your problem is one of the following:
secondary fuel pump (pickup pump)
primary fuel pump
fuel pump relay
fuel filter (cheapest, probably $5 or less, replace this)
vacuum leak
if your car runs fine, but idles like ***, it's one of these, and if your car is an early 90's car using motronic fuel management, it may just be a dying air regulator 'flap' or a corroding relay. my 91 16v golf had a crappy idle, and after a few $100 trying to find the problem, i said to hell with it
ROTFLMFAO!!!!!!!
who the hell let you anywhere near a car, oh jesus ooooohhh man thats good stuff... i think driver's ed should include basic automotive knowledge or at least require proof of non-retardation
wow, i was gonna take the time to type one of my usual more well thought out responses but wow, i'm just awestruck by your ignorance and stupidity, its sad that people with such a lack of understanding are allowed to operate a vehicle. i mean honestly, i dont know how to sew a sweater so i stay the hell away from a sewing machine.... if you're going to be operating something that is potentially dangerous than you should really learn what the f is going on.
glad a shop sold you a CO2 sensor, i'd do the same to obvious special ed students such as yourself.
//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif :clap: //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif :clap: well done sir, well done
Civic_boi334
Civic_boi334
Montgomery Al.
yacob.naif
