CMX kicks
it was the amp. i got a new one and it works now. but i got a new problem lol. its all static coming from my left woofer. left tweet is clear and all right components are clear, but left woofer only plays static. connection at xover and amp is good, didnt check inside door yet. could there be a chance that its the speaker itself and not a connection issue?
pull the offending speaker and check the connections. While its out move the speaker cone in and out gently and with even pressure and see if you hear or feel a scratching sound. If so, the voice coil is blown.
hey i got these speakers and granted i didnt read all 5 pages of post but
my tweeters also have the staticy thing... kinda.. it matters how on the song was recorded. it is defently slightly more noticable than with other speakers i've had in the past but doesnt seem to play freq's its not suposed to as you said earlier.. (just kind of a background hiss) - doesnt really bother me that much personally
and im running these with approx 200-250 watts per side at 80 hpf and they seem to take it well
well i still havent checked the connection in the doors but i doubt its that. the connections at the woofer are pretty solid looking. i also did some tests today. i switched around to different RCAs (RF, RR, LR) and nothing came outta the speakers at all. then i tried putting the speaker on a rear channel and still nothing. but there is something really weird going on. when i paused my music i heard static outta the left tweet. and when i unplugged the left RCA (to listen to music while working tonight without hearing the staticy left speaker) i somehow heard static outta the left tweet intermittently. how is that possible with no signal? also, when i had both RCAs plugged in i set my balance to completely left and i somehow heard static outta the right speaker. i have no idea whats goin on here. you have any idea?
maybe.. try to move the negative wired and test..
i jiggled the negative wire at the chassis and at the amp, and nothing changed. i also tried switching out the xovers but the problem still remained at the left components. i guess that kinda just leaves bad comps now doesnt it? i mean, what are the chances of a loose connection at both the tweeter and the woofer?
fatryan
Banned
fatryan
Southampton, Pa
fatryan
BP1Fanatic
BP1Fanatic
