cmx kicks on an Audison amp.....is it big enough??
yusoslo
va
I am buying some 6.5" CMX Kickbass components.
I love the reviews of the audison amps but the one I can afford is the 120x2@ 4ohms LRx2 series.
now I believe if I was to feed it a 2 ohm load from the amp I would loose my stereo sound correct?
This amp is 370 bucks new.......is there a better SQ amp for my money or will 120rms quality watts be plenty to make these speakers sound their best
i got a LRx2 powering 2 sets of eclipse comps (check sig) each speaker is 4ohm, so I hooked the fronts together to get 2ohm, and same with the back. Each channl is seeing a 2ohm load, all is workin and sounds good. LOVE the amp. Amazing clear highs. Everything is clean and sweet amp with TINY footprint.
I am buying some 6.5" CMX Kickbass components.I love the reviews of the audison amps but the one I can afford is the 120x2@ 4ohms LRx2 series.
120w a side for these with the passive crossovers should sound great. Personally, I would consider an Alpine 2.150 if you were considering a 2 channel option to power them. Actual test power for this is usually in the 160-170w range on the birthsheets, and the CMX Kicks can take the power no problem.
thats what I thought...bridging them would loose left to right stereo.
The alpine is a class D amp correct? so it wouldnt have as clear of a signal from what I understand.
alot of people say just get an amp with the power you need, but think there is a lot to say about circuitry and buildquality. In the past i went from a kicker amp to a memphis amp and found a whole array of music i never heard on the kicker. I hoonestly may go back to a memphis.
From all the input I've read on the forums from people that own the PDX series amps, they're highly efficient, and are very favorable because of the efficiency, build quality, and high power in such a small footprint.
I've seen the PDX 2.150's on Ebay brand new for about $200-$220 shipped. That's a great deal for that amp.
Just go with something like this deal, and save yourself the hassle.
http://cgi.ebay.com/Alpine-PDX-2-150-Mono-Power-Digital-Amplifier-NEW-07_W0QQitemZ130194642531QQihZ003QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You really won't notice THAT much of a difference between this amp an something from Audison, Zapco, Brax, or Arc Audio. Your wallet will notice the difference, but your ears most likely won't. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
they look like decent amps...but proffesional reviews have read said the PDX was more for a sub and being a class D is a turn off for me. This amp was reviewed as being a bit hollow in its sound reproducing and lacked midbass compared to other amps. As of now I have it narrowed down to a class A/B Audison and a Memphis M-class
memphis is 280
Audison is 370
The Audison is a great amp. I used to run them and loved the way they sounded. They often also underrate their amps. I would leave it as 120x2 @4 ohms. It will sound great.
yusoslo
yusoslo
va
LaserRed38
