clipping?
timaishu
So i went to a car audio shop today to see if they had a sub I was thinking of buying on the shelf that I could listen to.
I mentioned to the guy there that I have a 5-channel infinity reference 5350a amp. The amp puts out 300 RMS at 2 Ohms. The guy there said I should get this http://www.sonicelectronix.com/item_7065_Infinity+Reference+1052W.html
Well I then mentioned that I was actually thinking about getting this http://www.sonicelectronix.com/item_6926_Infinity+Kappa+104.7w.html
He said it would be a bad idea cause I would be underpowering the sub and that it would cause clipping and damage it.
Is this a valid concern? Wouldn't I be overpowering the other sub (250RMS) and damage that one too?
underpower has NOTHING to do with clipping.
go back, and kick him in the mouth for lying to you
maybe who told him that just didnt explain himself fully. maybe he was assuming since he was going to underpower it that he would set his gain too high in which case it would cause clipping.
so to clarify for the OP. No, underpowering something isnt going to cause clipping directly but if it isnt loud enough, since ur underpowering, you might be enticed to set your gain too high which would cause clipping.
Don't mess around with clipping, first you start off lightly, just the peaks ya know? Before you know it, your doin full square waves at full tilt wearin a backwards hat with the windows down at stoplights. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
and bust out every window in the neighborhood
Okay, that makes sense. Is clipping like distortion? As in, if it starts to happen, I can just turn the volume or down a notch and Im good?
Pretty much. Alot of people try to make up for a small amp by cranking the gain up. By doing this the amp is working beyond its limits (clipping). A clipped signal is no good for a sub
Okay, one more thing. If you were me, would you go for the kappa or the reference?
The only reason Im aiming towards the kappa is that it will take all 300 watts from my amp, while the reference will only take 50watts less than what my amp is capable of. Will it even make a difference?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If I were you, I would not listen to the guy at the shop since he is clearly retarded, and clipping may have killed his brain cells so he doesnt even know what he is talking about. Stick around this site and you might learn something. Read some threads and find out what you really want.
If you don't plan on upgrading anytime soon get the Reference. It's less money, more efficient (louder), and It will handle your amp just fine. IMO a overpowered sub sounds much better than a underpowered one
timaishu
timaishu
San Diego
Immacomputer
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
