It was fine for 15 minutes then you came out of work it was clipping?
can you elaborate more on this...
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif that would just make a hole in the sound, not cause them to blowmaybe the speakers are out of phase. they tend to sound like fart when you have wired one sub inverted from the other.check your wires for the subs on the amp + and - .
invert one of the speaker wires and there should be a sound difference, i hope it helps
what do u mean it sounds like an "*******". that gives no information. that could mean its not as loud, or that it is distorting. if it indeed isn't as loud then it IS possible that you have them wired incorrectly. BUT, since it just happened, i doubt u ripped out ur setup and switched your wiring during your lunch break //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifI would like to know why my speaker sounds like an ******* and not a speaker, I adjusted my gain, and HU, and still it does not solve the problem. Could it possibly be that the speaker is in fact out of phase?
so how are his speakers blown? sub just don't die from sitting there! with no power applied to them. if you have a multimeter check the voice coils for conductivity and or resistance. that should tell you if the subs voice coils are blown or not, " they could still be blown if the glue got burned of inside the sub" then check all your wiring from amp to subs and power. if every thing is nice and tight. power the system and look at your subs go, if they don't bet to the same direction then your subs are out of phase. reverse the polarity of one of the subs wires.
