Haunz
Packing 4/0
That is a negatory...the key seems to be the power supply. Without further knowledge, its uncertain what they mean by "digitally controlled" power supply. no mention is made of what the controller's goal is. Plenty of amps do use regulated power supplies for consistant performance. JL uses one to allow a wide range of speakers to be used equally well. Class G/H amplifiers use one to improve efficiency. Class D itself has a few variations to improve efficiency or accuracy as well.
my best guesses are that the supply is regulated* just like other class D amps. it may adjust itself as a class H amp would. this would bring about an increase in efficiency as switching losses would scale with the output level. but again, thats just a guess.
* keep in mind the "same power at any load" part of JL's RIPS is the I, not the R...
the PSU is loosly regulated, and the rail voltage does not swing with the input signal as it would with a class H design...
Its just a run of the mill class D amplifier...
