You'd have to make sure your amp is 2 ohm stable when bridged if you're going to do this.i just have them hooked up to there own channel. directly. havent thought about hooking them up as 2 ohm. ok thanks. if i wanted to make it 2 ohm would i hook a positive of one of my subs to the negative of the other the hook to positive on the one to the positive on the amp then the negative of the other to the negative on the amp?
He had the 46th post in this thread. What is the significance of the 46th post? There isn't one. He just wanted to use up a post.46th? what are you talking about?
