clarion apa 450 shuting down
the subs and amp are in a 2004 cavalier. i have the subs in the back the amp got mounted to the sub box so it could be over heating i am not to sure what the gain is at its the old ladys syst i got her for xmas. and i have one sub on the fornt bridged and one on the back bridged
almost every one of those we've sold has come back and the customer upgraded to a better amp, with only a few exceptions. for mids/highs they aren't bad for a cheap amp. but for running subs, you can do a whole lot better for just a little bit more money. the alpine mrp-m350 is a ballsy little amp, and is very cheap. great for subs on a budget.
but for your situation, turn the gains down. you can overdrive the input on those amps very easily, they don't like a lot of voltage. and if you are using the high level inputs, ditch 'em. they're nothing but problems, on those amps the high level inputs absolutely ****. real loose and shady connections on the cheesy little plugs they give you and we've talked with clarion about the issue, but have yet to see any changes.
first off, what kind of 10's? the alpine i mentioned before will get the job done very well, and is pretty cheap. the mrp-m350, you can find them new for about 100 bucks if you don't mind ebay. cheap amp, and very good power for the price, especially when you run it at 2 ohms. it is an amp designed for subs, as where the 450 is designed to run mids/highs. mono amps = subs and subs only. 4 channel amps = will work for subs, but not meant for it. much better suited for mids/highs.
JACKASS24
jackass24
JACKASS24
canada
JACKASS24
