XORstatus
CAR audio IDIOT :P
- Thread Starter
- #16
I UNDERSTAND what you're saying.put it in simplest terms i can for you:
as your sub plays different frequencies, the pressure that builds up on the cone increases/decreases... this creates more/less resistance on your coils. thats about as basic as i can get about it, without going into fluid dynamics, and other nerdy things... this is where the term "box rise" came from as well, as a free air sub wont have nearly as much variation in resistance, as an enclosed one... due to the pressures involved inside a box being much greater then free air....
Technically the impedance of the sub remains constant, however in reality the pressures built by the excursion of the enclosure and other assorted forces "INCREASE" the actual or perceived resistance.
Will this perceived resistance nuance altar the actual wattage (voltage or amperage) produced by the amp?
AGAIN not questioning your expertise, just trying to understand.
ALSO my port is thin, my enclosure is designed for more SQ than SPL, this will probabally substancially increase the box rise.
If im correct in that usage, box rise means other associated resistance aside form actual Impedance.
SEEEEEEE I MIGHT BE LEARNIGN!!!
