cl posting
treadburner
Car Sterio Amp - $150 (St. Charles)
Reply to: sale-1009217677@craigslist.org [?]
Date: 2009-01-26, 10:15PM CST
Hi Speed Digital Circuitry
New Hyper Bass
1 Ohm Stable
4-Way Protection Circuit
Bridging Synchronization
Variable Low Pass 40Hz-200Hz
Variable Subsonic Filter 20Hz-50Hz
Variable Bass Eq 0dB-18dB @ 45Hz
Phase Switch 0 or 180
Frequency Response : 20Hz - 200Hz
S/N Ratio : 100dB
THD : 0.5%
Master/Slave Function
System Distress Indicator
Dual Mono Speaker Output Connectors
Platinum Plated Heavy Duty Power & Speaker Terminals
SPECIFICATIONS
Amplifier Class : Class D
Number of Channels : 1-Channel
Maximum Power : 5500 Watts
RMS Power Output @ 4 Ohms : 1700 Watts x 1 Channel
RMS Power Output @ 2 Ohms : 2500 Watts x 1 Channel
RMS Power Output @ 1 Ohms : 3200 Watts x 1 Channel
Bridged Power : N/A
THD (Total Harmonic Distortion) : 0.5%
Signal-to-Noise Ratio (dB) : 100dB
Frequency Response (Hz) : 15Hz~150hz
Built-in Crossover : N/A
Subsonic Crossover Frequency : 20Hz-50hz
Low-Pass Crossover Frequency : 40Hz~200Hz
Bass Boost : 0dB~18dB
Bass Remote : Yes
Fan Cooled : N/A
Fuse Rating : N/A
Dimensions (Width x Height x Depth) Inches : 17.1" x 8.26" x 2.16"
Approximate Weight : 12.8 LBS
This is a Car Amp that is well worth over $275.00
You can have it for just $150.00 nothing wrong with it, it comes slightly used and in working order.
Will ship as long as buyer handles all shipping fees.
$150.00 OBO.
how much do u think it will actually put out at 1 ohm?
i might have to buy this if it will do a decent amount
well i dont wanna tell ya what to do because i dont have any personal expierence with the amp or anything but... like i said, dont go by rated.. but odds are it will put out more or a very comparable amount to any other amp you're going to find for $150..
but then again, wait for someone with more exp with this than me to decide...
treadburner
treadburner
st louis, mo
treadburner
