Circuit Breaker question.
Unless it's designed for 12vDC, I'd sugguest against using a circuit breaker. They are prone to not circuit break when they should sometimes. If you're installing one, it probably means you're blowing fuses. If you put a circuit breaker in there and it doesn't "break", then your amps "will".
not having a problem at all. infact i just started buying all the stuff for a complete system that I'm building and I was looking at the circuit breaker as an alternative.
I plan to remove my seats and carpet this weekend to run all my cables and speaker lines as well as RCA interconnects to my trunk. My plan was to get a fused distribution box but then I saw those circuit breakers.
lubetek
lubetek
Riverside, California
JCivicHb
