check over my design for a single xd8
trevor87
GEORGIA
have a single american bass xd8 going in a bmw trunk. running around 400 rms. does everything look ok here?
suggestions welcome
no just never used this program so want a 2nd opinion. Also the cut sheet seems off to me. if its a forward facing slot port wouldnt the front of the sub box be cut shorter?
You are right about the specs for the baffle being the same size as the rear. That can't be right with the port up front. Maybe that software just doesn't account for it.
I usually measure then sketch a drawing of how I want the box assembled and figure out the volume. Then I calculate the port using WinIsd and finally model the whole thing in sketchup.
You 'might' want to up your "port area per foot" a little bit. This might require you making the box slightly larger though. Someone please correct me if wrong, but I believe its a general rule that you want between 14-16 sq in per net cubic ft. The first box I built for my SA12 had 12 sq in of port per cube and my newest one has 15.5 per cube and I definitely noticed a difference in output.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
trevor87
trevor87
GEORGIA
eddie_93
SlugButter
    May 4, 2024
slater
    May 2, 2024
