Check my box...
Buck
little alien on campus
This is for an HDC318 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Out side dimensions-50.5 width x 20 height x 13 depth
L port will be cut in one of the 50.5 by 20 sides.
The port will be 18.5 x 5.25. The first port length will be 6.25 and the second will be 7.25.
Newb... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Jk.
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif The box for my 15 is now in someone else's vehicle. Good design btw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You actually want to check this for me?
I figured the expected port length to be 16.5" for a 6 cube net volume box tuned to 40 htz. Is that what you got? The gross size of your box is 6 cubes... There is no way you'll net 6 cubes after port and woofer displacement...
I was told that by someone (who runs aq and has been very loud with it) to make the box 6 cubic feet and then just make the port.
Well, that is great and all except you can't figure out port length unless you know what the net volume is supposed to be.
If you base your port length on 6 cubes net but your actual volume is 5 or so, your tuning will be way off. Compronde compadre?
That's what I thought //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
That box fit perfect.
Buck
Buck
Inside of a pyramid
Buck
