Check my big 3 list?
bikinpunk
G-g-g-g-g-unity!
I currently have only one battery terminal (pos) with 4/8 gauges. So I know I neither a new pos battery terminal. I have 4 running to the back of my car. Is there anything I'm missing here? I hope to order in an hour or two.
All products coming from Knukonceptz.
KLM0BL KLM Kable 1/0 Metallic Blue Power / Ground (10ft) $1.75 $17.50
BT-104P Positive Battery Terminal $12.00 $12.00
BT-104N Negative Battery Terminal $12.00 $12.00
RT1/0516BK Gold Plated 1/0 Ring Terminal - Black (3) $1.75 $5.25
RT1/0516R Gold Plated 1/0 Ring Terminal -Red (3) $1.75 $5.25
Total: $55
Everything seem in order?
This is my next upgrade so where do you get your stuff at?
Just curious if it is a MUST to run 0-1 gauge wire? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
It's not a MUST, but the logic behind it is why not do it right the first time, rather than need to upgrade to 1/0 later on? easier (and cheaper) to do it correctly the first time.
not fusing them???
x2
Thanks for the heads up on the fuse. Think 150amps will cover it. The wire is rated to 300amp, but my alt is 90amp? My amps are rated at a combined 135 if that makes a difference. I'll have to throw another $20 now...I knew that total seemed a bit cheap...
I'm ordering my stuff from Knukonceptz.com.
I agree doing 1/0 now would benefit you but do what you can get/afford... Bill at knukonceptz is great, hella products //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif good choice
bikinpunk
G-g-g-g-g-unity!
bikinpunk
Alabama
SPL140.2
BP1Fanatic
BP1Fanatic
