Check it out
You know what you could try, is this:
To bridge, since this is a two channel amp, look at the amp and do the following, run a line from the positive from the left channel and a line from the negative on the right channel. Now you have successfully run lines for a bridged connection. Next, seeing as it looks like the speakers you have can be run in a parallell connection, you can run them in parallel, in bridged mode on your amp, cutting the watts in half going to your speakers, so that they get an equal amount of power each, and it will help to save the life of your amp in the long run.
You know what you could try, is this:To bridge, since this is a two channel amp, look at the amp and do the following, run a line from the positive from the left channel and a line from the negative on the right channel. Now you have successfully run lines for a bridged connection. Next, seeing as it looks like the speakers you have can be run in a parallell connection, you can run them in parallel, in bridged mode on your amp, cutting the watts in half going to your speakers, so that they get an equal amount of power each, and it will help to save the life of your amp in the long run.
You mean a series connection, if you try to run that amp at 2ohms mono it will go into protection.
Heres an example of a series connection.
EDIT- this picture shows the speakers connected to only the right channel and does not properly represent a bridged amp, use the + of the right channel and the - of the left channel for bridged as greendog stated.
solidcrowd
solidcrowd
Buffalo, New York
stones
vegang
vegang
