Sold Cheap Amps: (2) 2k rms Soundstream PCA2000D's. (1) Cadence TXA 1000D
boostNbeer
Banned
CA
PRICE DROP - $180 for the chrome / $210 for the brushed aluminum
Getting rid of my little beasts.
The soundstream amps are a little different though, one is a chrome finish top and one is a brushed aluminum look. Both function perfect and correctly.
The brushed aluminum one cosmetically perfect aswell, but the other is missing its back cover ( it grew feet and left the garage aparently ) and the chrome has begun to tarnish on the top cover (its dusty as heck in the pics), Im sure you can make the back cover out of plexiglass or sheet metal, and paint the top if it bothers you, but Ill make that one cheaper
Heres the specs on theses beasts
# Monoblock Picasso Series Amplifier
# RMS Power Ratings:
* 1100 Watts x 1 Channel @ 4 Ohms
* 1500 Watts x 1 Channel @ 2 Ohms
* 2000 Watts x 1 Channel @ 1 Ohm
# TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
# High Quality FR-4 Circuit Board
# Class D Circuitry
# Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
# Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
# Variable Subwoofer Equalizer: 0 - 18 dB
# Phase Control: 0° / 180°
# Frequency Response: 5 - 250 Hz
# Adjustable Input Sensitivity: 0.5 - 4V
# Damping Factor: >200
# Fully Regulated MOSFET Power Supply
# PWM Circuitry
# Platinum Power and Ground Connectors
# Accepts up to 16VDC Power Input
# Wire Bass Remote Included
# Dimensions: 18" L x 9-1/2" W x 2-1/2" H
Good cosmetic one $230
Chrome finish one $200 Im aware its dusty lol, its been sitting for over a month in the garage, Ill clean it.
This is the cadence amp, Im sure everyone caught the forum boner a year or so ago. Its missing 2 set screws for the power and ground ($1 @ ace hardware) and is missing the bottom wire cover, what you see is what you get. Works perfect, does rated power or more.
SPECIFICATIONS:
4 Ohm RMS Power: 1 x 350 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 650 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
2 Amps Bridged 2 Ohm RMS Power: 2000 Watts
Frequency Response: 20Hz - 500Hz
Damping Factor: >500 @ 100Hz
S/N Ratio: >100 db
Minimum THD:
Dimensions: 25" x 9.2" x 2.12"
$100
Pm me any questions or for any specific pics or anything
boostNbeer
Banned
boostNbeer
CA
realdchild
