Charger+ 2 sets of rsd components in each doors+sundown= ````pics=====
Uhhhhh.....???
Why did you put 2 sets of cheap components instead of one better set?
Your supposed to cover all the holes in the door panels with the deadening material, and seal all the back sound waves of the speaker from reaching the front.
You need to move the crossovers out of the door. All doors leak, it's normal, that's why they have drain holes. Your crossovers won't last long in there.
Uhhhhh.....???
I know there are drain holes, but I have put many crossovers in my doors and not once have I ever had a problem with water getting to them.
I currently have my rsd's in there and work perfectly fine and I have been through some major storms.
depends where in the door they are at and if there is a way to stop water from flowing down on them i would imagine it wouldnt be that hard to do...thing is condensation can be a mother and if you wrap them in plastic how much would heat become an issue?
lookin pretty good so far. how are the baffels mounted to the door. if i were you i would turn it into some sort of fiberglass pod to seal of the front wave from the rear wave and give it some extra stucture
yes your crossover MIGHT get wet, maybe.
Heres what i do get a ziploc bag (sandwich size) drop the crossover inside letting the wires come out through the opening, then tape the shit outa the bag around the wire and no worries about water.
That doesn't really address why you used 2 sets when you simply could have gotten one better set for the price you paid for 2 sets.
+1
Best for the "money", but if you're gonna spend $200, should have got a nicer set of comps.
Also, are you powering both sets of comps with just the one sundown amp? Is that enough...
cdimic25
cdimic25
cdimic25
