channels question
Zach85
I'm thinking about buying a sub soon and getting an amp to go withi it. It is DVC, so I can do 4ohm or 2ohm.
I found an amp that I saw something I was wondering about:
250W RMS x 2 Channels @ 2 Ohm Stereo
does this mean 250 rms PER channel, so I could just hook my sub up to the one channel in a parallel connection, or how would that work if I only connected my sub up to just the one channel? Here are the specs:
Features:
Model: MA Audio 300XE
High Performance 2 Channel Bridgeable Car Stereo Amplifier
500W (Max) x 1 Channel @ 4 Ohm Stereo (Bridged)
125W RMS x 2 Channels @ 4 Ohm Stereo
Full MOSFET Circuitry
2 Ohm Stereo Stable
3-Way Protection Circuitry (Short/Overload/Thermal)
Selectable LPF/FULL/HPF Crossover
Adjustable Gain Control
Power and Protection LED Indicators
Low Level RCA Input/Output
High Level Inputs
Specifications:
Variable Low Pass Crossover Frequency: 50Hz-250Hz
Variable Bass Boost: 0-18dB @ 45Hz
Subsonic Filter: 20Hz-50Hz
THD:
Signal to Noise: 90dB
Channel Separation: 50dB
Dimensions (L x W x H): 9" x 10" x 2"
Thanks.
Features:
2 Ohm Stereo Stable
High Level Inputs
Specifications:
THD:
Thanks.
There is no DVC sub that can be wired to 2 ohm or 4 ohm. I'm going to guess you got dual 2 ohm subs. They can be wired to either 4 ohm or 1 ohm. If they are dual 4 ohm, they can be 8 ohm or 2 ohm. Figure out what each coil is on your sub and get back to us.
it is 4ohm DVC. I'm not worried anymore about this, I just saw last night during some extensive research that if you have DVC, parallel is much better than a series.
Well you're wrong. Parallel brings the impedence down. If your amp cannot handle that low of an impedence, you can cause damage to your amp and/or subs. Neither parallel or series is better than the other one all the time. One or the other is more appropriate for a given situation.
Zach85
Zach85
Schuylkill County, PA
Stalin-ohaulic
Mike Mccabe
