Sold CDT M6 Mids - $225 shipped
duece212
Buddy Christ!
I have a set of BNIB CDT M6 mids for sale. If your looking for a set of 6.5's that you can cross low and get tons of midbass from, these are them.
Looking for $225 shipped
Specifications
Diameter: 6.5” (170mm)
Sensitivity: 88.1 dB
Power Handling: 150 WRMS (300W Pk)
Frequency Response: 10 ~ 4000 Hz
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 1.37” (35mm)
Peak Xmax: 10mm
Magnet Weight: 30 Oz
Ok, just got a call from the suspension shop and my truck is done. Ontop of what I already paid my bill is $3700 //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
If somebody takes these off my hands before the end of the weekend I'll go $200 shipped.
bump for some killer midbass drivers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you sir, just too bad I won't get to try them out. I've spent too much money elswhere unfortunately so they gotta go //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
How would these do in a 2-way active setup with 110w a side? I'd like to be able to cross them as high as 3200kHz. Also, what is the mounting depth on these?
These would do fine on 110w a side, but could also take more if you ever decided to upgrade down the road. Mounting depth is 2.94"
These should be alright crossed at 3200, here is a review of them crossed at 3k:
I also got a little curious to see how well this driver would perform in a conventional 2 way component setup. I matched the M6 to a pair of CDT drt-26 aluminum tweeters and ran the setup active. The M6 was crossed at 60-3khz with a 12db slope and the tweeters crossed at 3khz up with a 18db slope. For this test I used my Jl audio 450/4 which sends 150x2rms @ 4ohm to the M6 drivers and 75x2rms @ 4 ohm to the tweeters. I played many of my favorite songs that I know extremely well and when I played Evermore's - It's to late (dirty south remix has to be this version) I couldn't get enough! The start of the song when the piano is playing is so precise with such great depth and clarity I repeated it a few dozen times. Midbass and midrange is very impressive for a driver that has so many uses. The part of the song that really shines is after the first part of the vocals are through and the beat bass line kicks in, The M6's reproduce how it should sound. Awesome punch, solid depth, and all the output you could ever want (at least for me). Now this driver is without a doubt great but do to its mounting depth, many will have to either mod there car doors or use a baffle/spacer to make it fit. Also if running this driver infinite baffle sound deadening is a must not only for ideal performance but also so you don't just hear the doors rattling away cause these drivers move air for a little 6.5". Many people that are not crazy about big subs and tons of bass or that just don't want to give up much room can also benefit from these drivers as they are a great way to get solid bass without the use of a larger sized subwoofer(s). If your thinking about running a 2 way setup and want the best midbass output you can find,
http://cdtaudio.com/m6_midbase_driver_08.htm
Here is the full spec sheet on the drivers: http://cdtaudio.com/pdf/HD-M6.pdf
duece212
Buddy Christ!
duece212
Colorado
duece212
