cdt hd-642 3way's
Clarify me here.
I want to get the hex6000, to run the upstage tweets (drt26?) and the hd-4 mids, and door tweets (drt26 silk?) and then get an active crossover (which one) to run the m6.
If you're using the Hex-6000 than no you won't be running anything active. You could run the M6 active if you did the HD-4 and tweeter as a two way component setup.
As for Intercooler's questions, they can be crossed over lower which can be nice in an active setup allowing for a little better blending into the midrange, I think i've said this before but you may want to check other aspects of the install if you've blown a few tweeters. Also switch to a Satnet 480 crossover with tweeter protection too.
Okay well then If the hex6000 allows you to adjust the power to the outputs for tweeters so the tweets are not getting as much power as lets say the m6.
How exactly do you go about ordering a "custom set".
I do it all the time but im sure other dealers can as well. I have even got custom made drivers from cdt a few times. I just got a custom pair of ES-06+ midbass drivers not to long ago //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif They might put them in production but doesnt look to good cause of cost and prolly not much of a demand for a midbass with 15mm of xmax and being 3.5" deep //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Although the HD-62 mid is good, and is astounishing for most, it would be worth your money to do the M6 upgrade and the 300 crossovers. The M6 is just //content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif
What also helps is the suspensions on them aren’t as tight as a virgin on prom night! Sorry I couldn’t resist using this joke 🤣
33
Holy **** dude went and manually deleted all his post one by one but said he doesn't have time for your ********. :LOL:
307
lrgnation
lrgnation
teh yay
PremierAudio
Decebal
    Jun 10, 2024
