3.5Max6spd
yo mama no wear no draws
Doesn't sound to me like 3way frontstage is in your best interest...A properly tuned 2 way active front yields nice resultS- in which a DRZ9255 will not be used to its potential and you can achieve BETTER tuning of those front speakers using another much more affordable deck- like i mentioned before the price difference between a a DRZ9255 and say an Eclipse 8series/Pio 860mp/etc...can get you a whole lot finer set of speakers.True. Acitve does sound a bit more complicated...but in the long run it would sound better I'm sure. I feel that the only pain in the *** part will be the tweaking and tunning..but that I can deal with. With any kind of system there will be tunning. As for putting in a 3 way component system...what kind of amp would I get for that....a 4 channel sure but.....would I wire the tweeter with the midrange together and then wire the mid bass by istelf to a channel? Also...I don't think I'd be able to put a 7 a 4 and a 1 inch tweeter all together in my door. Not enough room and i don't want to fabricate any kind of crazy kick panels. Want to keep the look stock for security reasons and "of ease" reasons. The only way I can see it working is if I take off my 6x9 speaker...then...use some MDF to make a converter...and maybe squeez in a 7 and a 4 together side by side...then put the tweeter where the other stock tweeter in the door above the arm rest and be done with it.
Anyways whatever you chose- good luck....at least you can sort out your needs based on the criteria discussed in this thread.
