aworldcollision
Thought this may be interesting to somebody. The 6 channels of the 9887 are full range. This means that after running a 3 way active system, if only using one subwoofer, the 6th output can be mounted in the center and Imprint tuned. The only downside has been that you need to run a bass knob for your subwoofer since your center channel and sub will be tied together.
This will give you the ability to maintain a higher SPL while keeping your highs and mids balanced since there can be, after all, 50% more drivers to share the load.
Stereo seperation is fine. I found no shrinking front stage problem. Tonality is perfect. Obviously the front stage is solid.
With all center speakers it is important to keep driver types unifmor as well as sensitivy considerations. Otherise you'll get varying responses at different output levels.
I installed a five inch, a five inch+3.5 inch +tweet, and now have two 3.5's installed. These are dome mids and sound great but will lack low-end response that you would get from a cone driver like the 5 inch.
This was/is an experiment that is successful enough that I figure it may be useful to others. I'd like to hear other experiences.
Remember that Audyssey is a hometheater tuning prgram. I believe that the Alpine has the same version just teaked a bit to tie the two subs together for car audio.
