CDA-9887 Active vs Passive
HNaga
I need your advice SQ guys.
I want to upgrade y current system
what do you recommend
1-SQ Passive Components speakers.
(What do you recommend to work perfect with Alpine CDA-9887 with Imprint)
2-Going Active
2-way or 3-way ?
what components for SQ?
my car has place for
6.5" speakers in the door and 2 tweeters as front
4.75" Speakers and 2 tweeters as rear.
Don't put rears in, if you can afford decent 3ways get them, and go active if you understand what youre doing. Since you didn't post a price, I'll assume you're rich, get a set of morel elate's and youll be the hottest thing in egypt
You cannot go active with a 3 way front stage with that deck. 3 way active means tweeter/midbass/sub. You would need a 4 way active processor and they are very limited and expensive.
I expected CDA-9887 has built-in active cross over for 3-way
4-way active cross over for 3-way.!! I don't understand that.
^ I'm 90% sure you can, but you wouldn't have a sub output.
Well yes you could do that if the lowpass will go high enough and then your stuck using the subsonic if its adjustable.
But even then like you said you will not have a sub preout
you cant run an active 3 way front setup with that deck, i know, i have it
the fronts run the tweets, the rears run the mid and the sub runs the sub
theres no mid bass channels
get some Dyns and a big 4 channel amp
http://www.dynaudio.com
I will try 3-way on y current system.
For passive I have 3 choices , Alpine SPX-17PRO , Pioneer PRS and Alpine SPX-17REF
I could decide due to too many different reviews.
I don't wanna compare between them in general , I want to compare based on the HU is CDA-9887
HNaga
HNaga
Cairo
macq32
