cd player wiring chart for 2006 honda tuscon
marcotheclepto
installing a cd player for a friend and wondering if theres a good site to find wiring diagrams? googling atm but not coming up with anything useful trying different seach terms. help would be appreciated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Never heard of that model honda you sure you have your info correct I just looked on crutchfield and all it dosent exists.
Also I take it you cut the factory harness off and dont know what wire is which?
If that is a yes than you should of just dropped 10 bucks for a wiring harness.
Also try a volt meter ground the balck and use the other wire to touch the wires in the sash that should tell you what wire is what.
Yello goes to constant 12 volts
Red only gets 12 volts when key is turned
black is ground
and speaker wires welll you just have to use a 9 volt battery and find out which wires go were.
Thats why if you did cut off the factory harness i pity you.
marcotheclepto
marcotheclepto
United States
marcotheclepto
