cd player want play cd's
  • 2
it spins the cd for like 10 mabye 20 sec then beeps and has a eq3 on the screen then it just goes back to the radio.
You can try the 'reset' button, should be a small recessed button on the front face when the detachable face is removed. If that doesn't work, and if it does this with all your CDs, then you have a bad CD player.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
368
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
tolow93
tolow93
ga
tolow93
    May 18, 2024
    May 16, 2024
