cd player voltage issues?
Ok so i bought another deck and it had the same problem. and then literally started sparking and next a small fire. I cant figure out what the problem is everything is def wired correctly.
So today i decide to say screw the factory wires from the car and run my own battery cable and a new wire to the fuse panel and a new ground. Everything is running fine now so far. What could the problem have been and is there a risk to me doing it this way?
Oh and also I changed the remote turn for my amps to the fuse panel instead of the deck
ok it did it again and i can smell a burning fuse i think. What else could cause this. Could the amps be doing it? like something coming through the remote wire?
Ok here is what I found today.
2 issues that could be the culprit
My 2 channel amp got pushed tightly against the back of the car causing it to cut though the carpet and touch against the bare metal of the care. and underneath the amp the remote wire had a very small rip in the wire surround causing bare metal wire to touch the bottem of the amp.
Im gonna assume this is what caused the probelms. But who knows
Ok here is what I found today.2 issues that could be the culprit
that sounds like it could have been the problem...
shortyg83
shortyg83
pa
shortyg83
