CB Radio Ground Wiring
You can ground it on the same ground as your head unit, but don't use a wire nut. Those are for home wiring, not car wiring. You may find it easier to ground the CB radio to some metal under the dash. Make sure it actually connects to the body, which you can check with an Ohm meter.
stormchaser2014
stormchaser2014
United States
stormchaser2014
michigan born
    May 14, 2026
michigan born
    May 14, 2026
